CAT100 - a cat food can thrower (100kcd)
Dr.Jones
Germany
Hi... I feel like posting my ...uhm... 'special' design thrower here, the CAT100, a cat food can thrower with 100kcd.
Inspired by aspheric lens based throwers I decided to try something like that on my own, but with sort of minimal workmanship since I don't have a hardware workshop. I took the biggest lens on DX, the 66mm lens, with an effective diameter of 61mm, focal distance of 44mm from the plane side, 67° aperture angle (full width), NA 0.55, and tried to find a housing for it. I ended up with a can from some cat food, adjusted with some pliers.
The battery compartment (14500) is rolled paper with a 1.0A linear driver taped on top and a left over tail cap clicky as switch. I'm clearly not happy with it's sloppy attachment to the body, but I just wanted it to work. The LED is thermo-glued onto a 2mm copper plate which is thermo-glued into the can.
I measured 104kcd (measured at 6m and 11m, with suspiciously consistent results).
Mounted on a tripod with clamp with one of my cats that somehow wanted to be in that picture, too:
Finally, some beam shots:
WPG
As you can see, "throw" depends on the brightness of the target.
It even lights up the stars:
(just kidding :)
That's a great idea !!! I also happened to have a cat ! I'll look into that.
This is what CPF is all about.. And I sure like it..
All the best,
Ra.
Who says Germans don't have a sense of humor!
I think you have the worlds longest throwing cat food can!
GREAT project- the dichotomy between the ghetto-quality construction and the astounding ghetto-lighting beamshots is magnificent!!!!
this is the ugliest homemade project I have seen here ... but it is the most throw cat food can !!!
:crackup: Awesome! lovecpf
Now, a redo with the label on the can is a must! ;)
That is hilarious. You even have a built in anti-roll feature. I also noticed you are using the EZ900 version XR-E. :naughty: I finally after all this time got my hands on a few.
Absolutely Class!
obviously 8 out of 10 flashaholics said their cats preferred it!
Imagine what you could do with a nice tin of Chum!!!!!! :devil:
lovecpf
LOL,
There is a host for this lens, it's an inexpensive DX shower head flashlight,
the lens will fit in with minor grinding on the edge, no need for a hardware workshop:
http://www.candlepowerforums.com/vb/showthread.php?t=264722
Can't wait to see your next Mod: CAT500, using 12 inch round Cat food bucket :crackup:
So does the light smell like Friskies once it starts to heat up and are you now being followed by hoards of stray cats as of late?:grin2: Nice Job!
