e-ville
man i just realized some of the captions i put over my pictures, im glad nobodies head was in the gutter haha
What if the unit was dropped whilst on and a droplet rolls onto the LED lens ?
Unlikely but possible, What does Thrunite suggest as a remedy in the event of this happening please.
Dear All:
Thank you for posting your concern regarding the Catapult. The oil that you are seeing is actually heatsink grease and is an integral part of the engineering that allows the Catapult to run a heat-generating emitter like the SST-50 on high for extended periods. The heat sink grease is injected into the LED and driver housing during assembly and has proven to be of enormous value in helping to dissipate the heat generated by the large emitter.
What happens to heatsinking when the flashlight runs out of oil? If it "has proven to be of enormous value" it is supposed to be important - having this oli inside or not having it should make a difference, right? On the other hand, it is leaking - so potentially there is less and less of this oil inside...
Is it supposed to be leaking untill some point only, stabilizing before some safe level is exceeded?
Thanks Olef. I was about to buy a Catapult. I don't want to have to regularly dismantle & clean it nor risk getting oil on the reflector. I'll pass and wait for an SST thrower that is easier to care for.
BTW even though it sounds like, and I imagine it to be mineral oil. Do not eat it, if I'm wrong it could prove to be pretty bad for you, then again it is ill advised to eat anything you don't know is safe to ingest, so you know, don't be stupid in that regard.
i must respectfully disagree. how can you properly assess the potential hazards of any unknown substance unless you perform basic tests? touch, tasting, consumption, exposure to an open flame or spark, slipping some into an oreo to feed to your neighbor's obnoxious-*** yorkie from across the street...these are all perfectly reasonable methods for learning about a product.
Tasting, consuming or burning certain sometimes household compounds is a horrible idea, and could kill you.
I can't respectfully disagree, what you have suggested is blatantly stupid in a lot of situations.
Fairly recently it has been found that break cleaner aerosol spray breaks down when exposed to heat and reacts to form phosgene gas (urethane products do this as well). In text it doesn't sound so bad, but phosgene gas is the main component of nerve gas, it's LD50 is quite low, low enough that it doesn't take much exposed to elevated temperatures to debilitate or kill you.
I don't want to hear about someone ingesting something toxic or igniting it and there being repercussions.
If you decide to do something so ill informed, it is your own fault, don't expect to sue someone for damages you incurred upon yourself. There are MSDS and warning labels for a reason.
You'll have to take to ThruNite dealer for an oil change
i wonder if i can get longer runtimes if i switch to 10W40
Is the excess that is being used something you are going to remedy? Even if it is an inert and harmless substance, it is obviously undesirable to have it escaping like this and migrating on to other components, such as batteries or reflectors.The escaping heat sink grease is simply excess and is tantamount to overly-lubricated threads.
