Cheap part for variable speed HF 8x12?
[FONT=arial, sans-serif]Works with any universal AC/DC brush type motor, 15 amps and under [/FONT]
Look at the outside of the motor ... if there are two removable caps that hold in a pair of carbon brushes, your good to go.
On edit, the HF site shows it has a single phase AC induction motor, which will not work with a router speed control.
I don't remember, since I actually never used the stock motor - I never turned it "ON". My AC motor was replaced with a 180V DC motor and KB 220V AC to DC speed controller. I don't even remember if I even have the old motor - I might have given it to DonShock when he bought my lathe back in December.
Will
I have used one of those speed controllers on my router. It absolutely will slow the router down, but it also kills the power. I tried it a few times and stopped using it.
I don't think the stock motor does have brushes.
I have that very same router speed controller from HF. I bought it years ago & forgot what I used it for. I do remember it worked for what I needed but I never used it again.
I never thought of trying it on the lathe & I don't think I will. :grin2:
Thanks, I think I'll go with my original plan of either adding an extra pulley, or making a hand crank for threading (mostly for internal threading). My reflexes just aren't good enough at the stock minimum speed.
There's a guy on the LM yahoo group that put a hand crank on the leadscrew (tail stock end) on the LM8x14. You can see pictures of it in the photos section. http://groups.yahoo.com/group/lathemaster/photos/album/1958881935/pic/list
Try emailing the guy, maybe he can probably help you or even offer the service?
Um, I think that's what it's for? :shrug:
