gunga
Here here. I agree. I guess the 4-5 year old preon revo on my keychain is here to stay.
This is data for the worm discussed above in this thread. Y axis is lumens, X axis is hours. To get the performance above, you turn the light on. If you want less light, turn it off and back on. If for some crazy reason you want more light, close to a binding 100 lumens, turn it off and back on again. You get this crazy output for 40-50 minutes, at levels the human eye can not detect a change of intensity, assuming you used a freshly charged eneloop cell. If you don't want this crazy amount of light, just turn it on once with an alkaline or eneloop, and see the chart above.Tested Medium, the worm is regulated and lasts past the 4 hour mark when I ended the test because the ReyLight turned off by then.
Does this light not meet that description? I am confused . . .:shrug:I, for one, would rather have less maximum output of regulated light, than a light that bright and not fully regulated. It appears those days are over though, as the makers think that brighter is always better.
I thought the Worm was my control?There really needs to be a control added to the test
Hoping the Maratac being discussed … has a similar performance.
What I've quickly learned is today's 1xAAA lights (Lumintop and ThruNite for sure) have thrown any chance of flat regulation across all modes out the door, because of introducing this record setting high-output found in these new LEDS
So mutch testing, and still no one have tested it with a 10440 :devil:
bottom line is the new Maratac driver is more efficient on Eneloops than the previous run of drivers in the Copper and Titanium Tools.
I missed that, got link?It's already been determined that Maratac Rev.4 driver accepts AAA voltages only.
why do you ask, is the info not on the charts I posted?Those drivers have identical lumen output in the modes you tested?
The original PWM-laden Maratac Rev. 3 circuit (PWM on M and L only) could technically handle 10440 voltage, but not for long with the stock aluminum heat-sink. Copper-bonded LED provides much better performance, endurance for these, throwing away destructive heat.
The newest batch of Current Controlled (CC) Rev.3 (some CPF-members title it "Rev. 3.5") circuits (no PWM on any mode) are predicted to instantly on 10440, according to the manufacturer, Lumintop, which uses a near identical driver in the new Tools. This is not due to heat but the voltage limits of the new driver.
I have not seen any reports of anyone, successfully or otherwise, using 10440 in CC Rev. 3.5 Maratac lights, which voids the warranty.
Well, that's due dilligence.
So if you are braver than we are, and throw circuit voltage limits and caution to the wind, please let us know what happened to yours.
edit: looks like somone has tried 10440 in a new Tool:
http://www.candlepowerforums.com/vb...-REVIEW-Lumintop-TOOL-AAA-(XP-G2-1xAAA-10440)
so there is a slim chance of the hard voltage limit of the new CC Lumintop driver (also used in Maratacs) being exaggerated... need more data.
edit2: My guess is that Tool was from the last batch, with PWM, not the new CC driver.
I got one of those too, it is pictured above, including the lack of ring around the LED.
Maratac Rev3 had a second production run, I bought one in October, pictured above with the ring around the LED and it is the first Maratac Ive owned with No PWM. We have started calling it Revision3.5, but that is not CountyComms designation, they still list it as a Rev3. I bought Rev3 Maratacs in April and in June also, they both had PWM and no ring around the LED.
Honestly, I dont think it is any better to run a 10440 on a stock Maratac with or without PWM. Its just wrong to use a battery that exceeds the voltage rating of the driver. I do not recommend 10440 in lights that were not designed for it, though many here report enjoying living more dangerously..
I hope the OP does not fry his light dead, but I dont think he will. Im pretty sure regardless of Rev3 or Rev3.5, that once he starts using LiIon, the light will no longer work on AAA batteries, Ive read that report often. Not that it matters to people who want to use 10440.
As to the question of brightness modes on LiIon, figure about 4 times the levels of AAA.. Stock Maratac Rev3+ modes are 40-1.5-138, so on LiIon I might expect 160-6-552(for a few seconds)…
The key is to look for the ring around the LED. FstopLights was selling the earlier PWM based Tools with no ring.
I look forward to the OP sharing whether his Maratac has the ring around the LED, and how his LiIon experience works out.
Video says dont use a 10440, you will blow the driver. If it uses the same driver as the lumintop worm rev 4, then a 10440 will blow the driver. Done that.. My worm only works with a 10440 now, and it's only one mode now.
Sorry if I came across in a bad way, it was not intended. I was just not sure if I was missing something.I'm going to disengage from this thread, as I don't want to take it off track anymore than I already have. Sorry about that. Yes, I guess you're right. If you want the regulation, don't use high. It so happens, the T01 (that I measured) is a single level light. Again, not part of this thread or discussion, so I'll take a seat.
No. It's all good. This really wasn't the thread for me to start adding additional products.Sorry if I came across in a bad way, it was not intended. I was just not sure if I was missing something.
I own all of these models (including all PWM and noPWM Maratacs) and they work perfectly with 10440 in my experience, YMMV .jon_slider said:... The Maratac, Lumintop Tool (Copper, Alum, Ti, Rey Light Tool (Copper and Ti) and Worm (Copper, Stainless and Alum) in their present versions all use the same NoPwm driver afaik.
Beautiful lights! Congrats
