Sold/Expired Chimera Mini Pre-Pay Sale
Sabrewolf
Ambler P.A.
Chimera Mini Pre-Pay Sale (Added Bead-Blasted Finish Option)
I added another finish to the lineup.. Stonewash :) That makes 3 seperate finishes
that will work with any of the options below.. More pictures on page 8 :)
The Stonewash is VERY difficult to make it look like the test-finish body you
see in the pictures below. It typically comes out look a duller-grey with a tighter
galvanized look. ALL 3 of these finished come as a Base Finish with the basic
price of the light (425$), Ie, They do not cost Extra. Just tell me what you
want on the light. You can even mix-match the finishes with the top and
bottom side of the light. So, Stonewash on the bottom, And beadblasted
on the top cover.
Satin on left, Bead-Blasted in the middle, And Stonewash on the right :)
Pick what you want, And let me know!
Previous thread in the Homemade and Modified Section.
http://www.candlepowerforums.com/vb/showthread.php?t=212213
A Short Review can be found in post #73
http://www.candlepowerforums.com/vb/showpost.php?p=2906979&postcount=73
Please Read this Entire post Before you buy the light.
I want to make sure you know All of the options and
specifications before pulling the trigger.
And if you have Any questions, Please Ask :)
Well, After many months of prototyping and planning... Here we go...
The pre-pay will be for the Full amount of the light,
Plus any options that would like.
Gen3 Production Model
The "Patterning" Will be an Extra Option.
See below in the options section.
(This light was not yet built up at picture time)
These Pictures are from my machinist :)
That is V10 Green Glowpowder Behind the lens.
His camera did not "Capture" the Green properly.
Specs:
: 2.7" X 2.2" X 0.4" Thick Or 68.8mm X 56mm X 10mm
: MC-E Led in Coolwhite (~400 Lumens) Or,
MC-E Led in Warmwhite (~350 Lumens)
See the Picture below for the color difference.
: Lithium Polymer 800mA Battery rated for 10c or 8Ah discharge
: MaxFlex3 Driver configured for 1200mA Max Drive Current,
Driving the led with 600Ma per die on high.
Setup for UiP mode (Portable/Flashlight mode)
: 5 Level Output With High Being One Click Away
: Seperate Leds for battery voltage and charging status located
under the power button.
:Glow powder will be behind the lens and charged by the led
(color choices are ocean blue, red, orange, green, white, and
pure blue) Glowpowder info at www.Glowinc.com And pics of the glow:
: Built-In USB Charging Circuit with a charge rate of 300mA (revised)
: Built-In MicroSD Reader/Writer with a max card capacity of 32Gig
When you plug the light into your computer to charge, The MicroSD
adapter will popup a drive letter for you to use as a flashdrive.
If you do not install your own card, Then nothing will happen.
I will offer cards in 1,2,4,8,and 16gig sizes if you dont want to
source out your own. The adapter will also support Windows Vista
"Readyboost" feature if you use a class 4 card or above.
To install the card, you unscrew the top cover, Lift the battery,
And slide your card in. Replace your screws, and Viola!
: 2 Sets of screws included. Black Steel and Stainless Steel
You can mix and match any combo you like :)
(Use a .05 Allen key or Torx T5 driver)
: Runtimes and Lumen Output:
(Runtimes and Lumens are Approximate numbers)
Level 1 10 hours at 40 lumens
Level 2 6 hours at 75 lumens
Level 3 4 hours at 150 lumens
Level 4 50 minutes at 250 lumens
Level 5 15 minutes at 350 lumens
If you leave Level 5 on continuous, The light
will drop to level 3 after 1 1/2 mins or so due
to the heat buildup. This is a function of the
MaxFlex3 driver to protect itself, and the batt.
(I will finish the figures when i have more time)
And the light does get fairly toasty on level 5
right behind the led. But the heat will start to
move to the front edges, and top of the light
in a short time. Level 4 and below are usable
in a continuous fashon.
This is an MC-E color comparison pic between
several different lights.
These prices are for the first batch of 30 lights.
That means its an "Introductory Price" < No More!
Prices will not change over the initial batch of 30....
$375 for Aluminum in 6061 (Anodized Black HAIII) The aluminum
version is Not available yet. So all models will be Titanium for now.
I just wanted to show you the price when it becomes available.
I don't have a timeframe on it yet due to the focus on the Titanium.
The design will also be a bit different too. So i will startup another
Thread when that happens.
$425 for Titanium in Grade 2 (99% pure Ti W/Satin Finish)
A home charger, Lanyard, And a Different set of screws (stainless).
A Mini-Usb cable will also be provided for connecting to your PC/Mac
Continental U.S. Shipping included. International is Extra.
Payment Options:
Check, Money Order, Or Paypal.
PM me for my address for the checks.
Paypal: robertkmagill AT hotmail.com
Please Add 4% for paypal fees if you
don't have a "Funded" account.
That means you have to have a Bank
account linked to your paypal account.
The Funds draw directly from it,
And Not your Credit Card.
Options: (I will have the rest of the prices shortly)
: MicroSD cards in 2gig 8$,4gig 11$,8gig 21$,16gig 50$ sizes.
: Money/Belt Clip. Titanium Construction. Final Price! Price $35
The clip Must be taken off to use the 1/4-20 Camera Mount if you opted it.
That is a Handmade Prototype clip you see below. The Final version will be a
bit thinner (.035in) and longer (closer to opposite end) Screw options wil be,
Blackened or Body color. The screws will be countersunk to allow tailstanding
If you wanted the clip installed Bezel-Down. (can go both ways, Just specify)
Also, You can opt for a Countersunk mount into the body, or not. So if you want
to take off the clip, There won't be a sharp edge there.. Just 2 screwholes that
can be filled with set-screws for water-resistance.
Added an Option!
For those who want the option to reverse the clip to the opposite end:
You can opt for non-slotting (no flushmount) of the body for the clip.
I will drill/tap 4 holes in the body (both ends) and supply you setscrews to
fill the holes that aren't used. That will help keep the water resistance
properties of the light. The light will Not tailstand if you install the clip
in the bezel-down configuration due to the use of button-top screws for
fastening the clip. Countersunk screws won't work with this option.
: 1/4-20 Mounting for Camera Tripod (Custom threaded from backside) 15$
The Threads are "Square Style" similar to Jetbeam lights. That means they
won't accumulate as much lint and grit from your pocket as a regular style
45 degree thread. The Screw depth CANNOT Exceed 1/4in (damage will result)
I finally found a good source for the mini tripods... They are 5$ each
Here is a different style that wraps around stuff.
: Tritium Markers Installed Using the templates below. Each individual Slot is 15$
If you wanted "Just" the Trit Slot/s for your own install then it will be 10$
Tritiums can be found here:
http://www.cpfmarketplace.com/mp/showthread.php?t=183824
: Custom Satin Finish with Polished Edges (Seen here on the Gen2) 25$
Or Opt for the X-Men Theme On the Front or Back,
Or Both sides if you prefer. (Same 25$ price as above)
If you want custom artwork done, Please contact "Pontiaker" for prices.
He does metal carving similar to how a dentist carves out cavities.
Here is a thread of his work on a 007:
http://www.candlepowerforums.com/vb/showthread.php?p=2836916
For an Engine-Turned Finish (pearlie swirlies as i call them)
15$ per top OR bottom, And 10$ to do all 4 sides.
For the Machinist own custom plaid-like finish, it will be 50$ extra
Each light has its own Unique finish, So no 2 will be alike.
New Option!! Ipod Shuffle 150$
Please click on the link for more info.
http://www.candlepowerforums.com/vb/showthread.php?t=259385
Tritium Locations. Please ask B@rt for 1.55mm X 5mm Sized Trits.
The 1.55mm trits are actually the same thickness as the top cover.
So the milled slots will go all the way through the cover to accomodate
them. The Norland 63 will seal them up nicely, So there are no worries :)
Just pick the letters of the slots you want me to mill. And i will install the
trits in them with Norland 63 Optical adhesive. Please contact B@rt for the
colors you want, And purchase them from him. Have him send them to me
directly for installation. That way, If there is a color thats not available,
He will let you know. This eliminates the Middleman (me) in case of any
communication problems. Pick your letter, and color combo for install.
Ie, A-Orange or C-Green... You could even have Every slot filled :eek: :)
Keep in mind that this is the Gen2 light. The Gen3 Production Model has
the middle screws in the top cover moved slightly to the front of the light.
Look at the "Machinists" pictures to see what i mean.
Previous Versions:
My Handmade Aluminum Prototype
Gen1 Titanium Machined Prototype
Gen2 Titanium Machined Prototype
Family Photos:
Member List
1 Hamheart Warmwhite (Gen2 Prototype) Shipped April Tracking Info Sent Paid
2 Russtang Warmwhite, 8gig, Moneyclip B/U, Polished Edges, Trits (#3, C, G) Shipped on June 30th Tracking Info Sent Paid
3 Karlthev Coolwhite, Blue/Green Glow, Polished Edges, 8gig Shipped on July 21st Tracking Info Sent Paid
4 Morelight Warmwhite, Green Glow, Shipped on June 17th Tracking Info Sent Paid
5 Sjalbrec Coolwhite, Ocean Blue Glow, Machinist finish, Reversable Clip (4 Holes), 8gig, Trit install (M) Shipped October 20th Tracking Info Sent Paid
6 Brighterisbetter Warmwhite, Money Clip B/U, Green Glow, 4gig Shipped on June 30th Tracking Info Sent Paid
7 Jojobos Coolwhite, Moneyclip B/D, Green Glow, 8gig Shipped October 20th Tracking Info Sent Paid
8 Scout24 Coolwhite, Blue Glow, 4gig, Polished Edges,Moneyclip B/D Stonewash on Body/Clip Shipped on July 4th Tracking Info Sent Paid
9 Reptiles Warmwhite, Green Glow, Trit Slots (1,M), 4gig, Polished Edges,Moneyclip Shipped on July 21st Tracking Info Sent Paid
10 Acourvil Warmwhite, Money Clip, Green Glow, 8gig Shipped on July 21st Tracking Info Sent Paid
11 Iconoclast Trit slots (q, r, u, v, j, p, m, c, g) Moneyclip B/D Shipped on January 9th Tracking Info Sent Paid
12 MWClint Warmwhite, Blue Glow, Trit Slots (2,4) Shipped October 20th Tracking Info Sent Paid
13 GryphonQ Artwork, 16gig, Moneyclip, 1/4-20, Trits, Polished Edges Base Light Shipped October 1st Tracking Info Sent Paid
14 Straylight Coolwhite, Ocean Blue, Polished Edges, Moneyclip B/D (body color screws) Shipped on September 30th Tracking Info Sent Paid
15 NFetterly Warmwhite, Blue Glow, Trit Slots (1,M,P), 8gig, Polished Edges, Cam Mount Shipped on January 9th Tracking Info Sent Paid
16 Rkjr Coolwhite, Ocean Blue, 16gig, Pearlie Swirlie Finish, Reversable Clip (4 holes), Trits (L, N) Shipped on July 21st Tracking Info Sent Paid
17 Amorphous Coolwhite, Ocean Blue Glow, Moneyclip, Camera Mount, Trits (H,i Self install) Shipped October 20th Tracking Info Sent Paid
18 Incidentalist Coolwhite, Ocean Blue Glow, Reversable Clip, (4 holes) Shipped on September 30th Tracking Info Sent Paid
19 Flymatt Warmwhite Shipped on October 16th Tracking Info Sent Paid
20 Paa100 Coolwhite, Green Glow, 8gb, Carbon Fiber Cover, Reversable Clip, Trits (#1 Red) ShippedTracking Info Sent Paid
New Batch
21 Dcaprilla Coolwhite, Red Glow, B/U Moneyclip (flushmounted), Trits (1,M,R,Q) Shipped on December 12th Tracking Info Sent Paid
22 Doc Coolwhite, Green Glow, Cam Mount, Side Grips, NO Lanyard Hole, Trits Self-install (1,L,M,N) Shipped on January 9th Tracking Info Sent Paid
23 Reptiles Warmwhite, Green Glow, B/U Moneyclip (flushmounted), 8Gig, Trits (1,M) Paid Shipped
24 Smack2000 Warmwhite, Ocean Blue Glow, B/U Moneyclip (NON-Flushmounted),Non-Countersunk Top Cover Screws, Cam Mount, Stonewash Finish/Clip, Trits (Tri-Equal Sign) Shipped on January 9th Tracking Info Sent Paid
25 NCBlades Coolwhite, Ocean Blue Glow, Beadblasted/Stonewashed Shipped on June 24th Tracking Info Sent Paid
26 Fizzwinkus Warmwhite, White Glow, Finish to be decided, Micro-USB, Trits (Vertical Tri-Equal in "M" here http://www.candlepowerforums.com/vb/showpost.php?p=3237424&postcount=663) Shipped on Sept 7th Tracking Info Sent Paid
27 Ducati900sp Warmwhite, Green Button, Scalloped Sides and Back, Heavy Stonewash, Flushmount Bezel-Up Clip, Trits Vertical "M" (Regular A, B, F, D), And... Double 2 and 4 Shipped on Sept 11th Tracking Info Sent Paid
28 Ducky Coolwhite, Green Glow, Satin Finish, Black Screws Paid
29 Reptiles Warmwhite, Green Glow, Non-Flushmount Bezel-up Clip, Trits (1,M)Paid
26 Fizzwinkus Warmwhite, Will add more options Paid
More can be made!!
To Everyone! That means You :crackup:
Please make sure you specify what color led you would like
(Warmwhite or Coolwhite)
What side or sides you would like the X-Men finish
(top or bottom, or both is the same price)
The same applies for the polished edges.
What color of Glow Powder you would like behind the lens.
(See first post for colors, But you can opt for No Glow if you want :) )
Moneyclip Direction
(Bezel-Up or Bezel-Down)
Make sure you get your Tritiums from B@rt if you wanted me to install them.
PM me for my address so you can send them to me :)
http://www.cpfmarketplace.com/mp/sho...d.php?t=183824
(The price for "Just" each slot for self install is 10$)
(If you send the Trits to me for install, Its 15$ each slot)
(If you want me to install them, Let me know what color goes where)
WOOOOOHOOOOO
The CLIPS ARE IN!!!!!
Just have to clean them up, and bend em!!
You can see the nice big sheet of Titanium
they were cut from too :grin2: I just pop em out
like little model airplane parts :nana:
Bent Clips this time!!
They are all ready to go!!! (Shoot me a PM if you want one)
The design is updated, With a crossbar in the middle for more stability.
I need to fill the orders for people that are waiting on thier clips first.
Anyone who allready has a clip can purchase one of these for 10$
to keep as a spare, Or replace the current one you allready have.
All existing chimera owners can get a clip installed for 35$..
But only as a Bezel-Down setup. I cannot install them the other way
without having to redoo half of the light's insides due to drilling
and tapping holes in the front (for bezel-up). Bezel-Down is easy
because i can move the battery out of the way to drill/tap holes.
Ohh, Trits can be mounted in the middle bar if ya want.
The 5mm variety are whats needed.
Please let me know ahead of time so i can have the machinist
mill the clip for the trit(s) Before i bend them.
That means i bend them to order, And not before..
Different finishes and patterns can only be done while they are flat :P
PM Me if you have any questions :popcorn:
:eek: WOO HOO!!!!!!!!!!!!!!!!!!!!!!!! The prepay has started!!!!!!!!!!!!!!!!!!!!!! P.M. incoming tomorrow. :twothumbs
PM sent (money order payment)
Titanium Chimera $425
-Warm White MC-E
-Pure Blue Glow Powder
-horizontal ice-blue trit + slot above the button
Thanks!
-Clint
Curious on 2 things..
1-Price/placement of the 1/4-20 hole. Any chance you can draw a dot on the back of the final proto to indicate the approximate placement? I ask because if I were crazy enough to mount this to a camera of some sort, I'd love to know if its going to be off balanced or more central.
2- I assume if I want to do my own trit installation and just require slots to be milled that it would be cheaper?
Damn, time to sell things.
That is basically the only place i can put a 1/4-20 hole
since the light has shrunk in size from the first proto
Yes, the milled slots would make it cheaper for you.
But i still have to figure out the pricing on it :whistle:
And i will put up a picture of where the slots would
potentially go.
PP sent for a Ti Chimera. I still have many questions but wanted to reserve a spot for the first run of 30.
Are all 30 going to be titanium, or is part of the pre-pay for the upcoming aluminum version?
Is the trit slot fee per slot (probably)?
Trit locations limited to those shown?
Is the money clip design same as on the aluminum prototype?
Money clip fee?
Fee for machinist's personal finish?
Is the "x-men" finish an additional fee on top of the satin/polish combo fee?
Choice of screw type and finish?
Are there actual separate LED emitters to show voltage & charging?
What color glow is in the photos from the machinist?
Complete lumen/runtimes?
:takeit:
Titanium with satin finish and no extra holes for clip, mount, or vials (I can mill those later if I decide I want them)
Green glow powder
Warm white LED
No memory chip needed
No artwork.
I will be sending PP on Sunday.
Thank You, Dwayne
Hey stray, I can only guess that they will all be manufactured out of titanium (and the fact that it says the aluminum wont be available for the initial batch)
Wow!
I have so enjoyed following the progress of this creation:faint: I am currently paying for a wedding and could only dream of owning one of these, but Damn they are a thing of beauty! What a great design Sabrewolf:twothumbs This is truly the EDC!
PP sent for a Ti Chimera. I still have many questions but wanted to reserve a spot for the first run of 30. Is that the way this works, because the original "order" list vs an actual "paid" list is not at all clear.
Are all 30 going to be titanium, or is part of the pre-pay for the upcoming aluminum version? All will be the Titanium version. The aluminum is still in the prototyping stage. There is a bit more to "Just" making the same light body in aluminum. The top cover will also be thicker to keep it from flexing if you stick the light in your back pocket and sit on something. It may even have to be titanium, Or stainless.
Is the trit slot fee per slot (probably)? Yes
Trit locations limited to those shown? Send me an idea of what you want, and i will see if its possible.
Is the money clip design same as on the aluminum prototype? I am not sure yet.
Money clip fee? Not sure yet. But i will let you all know next week because i am looking for a very elegant money clip to cannibalize..
Fee for machinist's personal finish? I'll let you all know this weekend.
Is the "x-men" finish an additional fee on top of the satin/polish combo fee? It is the same price for the X or corner polishing. I may do more types too.
Choice of screw type and finish? 2 types are included, and are the only ones available, Black Oxide Steel, and Stainless Steel.
There are 2 different leds, Red for low battery warning, and Green for charging status.
What color glow is in the photos from the machinist? It is a Green glow. But the camera he snapped the picture with makes it look blueish..
I am going to try and finish the runtimes chart soon. I just have to make time for babysitting the light (pay attention when it shuts off :) )
Thanks for your payment too :) I will note it on the list.
Hey stray, in the first paragraph it says theres gonna be only 20 made, I can only guess that they will all be manufactured out of titanium (and the fact that it says the aluminum wont be available for the initial batch)
True, 20 in the first run, but a "guaranteed" introductory price for the first 30. There were more than 20 people on the list when the sale thread was posted. Have they all paid and the first run of 20 spoken for?
Sabrewolf, thanks for posting additional details for some of the options. Pretty excited about this light (obviously).
:takeit:
Green glow powder
Warm white LED
No artwork.
Thank You, Dwayne
:paypal:
Okay folks, It has taken me a whole day and a half to finish
the majority of the first post to include options, and some of the
prices. But there will be some more editing, As some prices are
not figured out yet. If you have paid the Base price of the light,
And want more options (as i add prices), You have until April 20th
to make up your mind. That means if you thought you wanted "just"
the light without any options, and you changed your mind before
that date.. You just let me know, and shoot the payment difference
right on over :)
More to come! :thumbsup:
Totally sweet...what a design...may have to get in on the second batch :popcorn:
