Isopropyl Alcohol on a Q-tip works every time with no threads left on the dome. Give it a minute to evaporate off the dome and leads before powering up. Isopropyl Alcohol is recommended by Seoul Semiconductor, from the .pdf on pg.15:
• This device should not be used in any type of fluid such as water, oil, organic solvent and etc. When washing is required, IPA(Isopropyl Alcohol) should be used.
