belomeclone
- Joined
- Oct 13, 2009
- Messages
- 212
So I have to go to Radio Shack and buy some Deoxit, put that on the q-tip, and swab up inside it where the battery connects. Then I take off the O-Ring. Then I alcohol up and clean the threads (Do I also clean the body, or do I not want alcohol near the contacts). Then I lube up the O-ring (and the threads?) (Do I put the O-ring (it's very small) in a bag with some thermal grease?) THEN I put the O-ring back on and it should all work?
Is that the directions I should follow? Do I also have to lube the entire interior of the flashlight up? That's what I've got so far, any advice on fine-tuning it? And while I know enough that Deoxit is what to get (though not sure which of the two in the two-pack to use), any certain grease to get (Superlube?) or just get whatever?
What has been my guide (last updated in 2007) says to not get the Radioshack Double Pack because it is aerosol and contains only 5% of the product. Is this advice to be followed? Also, the Double Pack comes with Deoxit and Deoxit Gold. What is Deoxit Gold used for?
Anyway, I have the general idea, right?
