Constant Resistance Discharge Curves?????
saildude
Seattle
Has anyone done some constant resistance discharge curves??
I have seen a few at the battery mfg. sites but not much.
Reason for wondering is that it seems that if a LED Light manufacture matched the Led to the battery and skipped any voltage regulation other than a resistor that they could have a very flat discharge / light intensity curve.
I have seen many constant current discharge curves here but did not have any luck finding a constant resistance curve.
thanks - mb
1) I think you're misunderstanding the meanings.
2) There are pleanty of constant resistance discharge curves around here, they just aren't called that.
"constant current" refers to a popular method of creating a regulated flashlight, where the circuit provides a constant current to the LED for a relatively constant brightness. There is also voltage regulation, but it's not quite as common.
Most lights that have no circuitry are simple resistor driven lights, and their curve would be a "constant resistance" curve. These include most lights that use 3xAA's or 3xAAA's. Taking 3 cells is usually a dead giveaway that they don't use a boost circuit, and are most likely cheap resistor driven lights.
Constant current designs usually give a very flat discharge curve, where simple resistor driven lights will have a steadily declining output curve.
