PhotonFanatic
I've always wondered why LED manufacturers insist on making star shaped bases instead of round bases, but have never found a good answer.
TB's post about his turning down a Cree Star to fit the Aleph LE got me motivated to make a jig for transforming any star based LED to a round base. But I was interested only in trimming the base to match the bore for a 20mm reflector, not the Aleph LE diameter; my target diameter: 19.50mm.
First, I made a jig to be used with my collet--a six-pronged jig that would allow the collet to press against the prongs and hold the star in place while it is turned down. But I also needed a spacer block to position the star away from the collet, too. Here are the pieces:
In use, the jig is inserted into the collet:
Then the spacer block is inserted:
And finally, the Star is added:
The star is then turned down in the lathe:
Before and after pic:
No, I didn't lose the LED while turning the base--I started with just the base.
If I want a smaller ending diameter, I would make two new jigs--one with three prongs to hold the star so that the cut-outs for the wires/optic/screws can be made deeper. Then I'd make a smaller diameter six-prong jig for the turning to the desired size. For now, this 19.5mm size is what I want.
