I used to think that the DX11836 single-mode R2 drop-in was a good, low-cost option. But I've changed my mind. For me, it runs too hot for very little gain vs. the old, tried-and-true DX6090. In a plastic G2Z, I think that the heat generation would be especially problematical.
When I put 3 different DX11836 drop-ins on a bench power supply, they all showed very poor regulation performance. They appear to run in full regulation when the input voltage hits ~4.5V. But they are grossly inefficient (as a rule of thumb, assume an LED Vf=3.5V@1A, or 3.5W of power draw by the LED), pulling 7W-8W and fluctuating fairly widely in power consumption (up to ~1A delta). This is 50% or less driver efficiency. Then at around 11V-12V, the driver suddenly pulls only about 5W-6W (which is still very inefficient).
In contrast, the DX6090 shows the classic step-function shape for its buck regulated behavior. At about 5.2V, the driver starts to run in full regulation. It holds a steady 4.2W-4.35W of power draw out to 14V (I didn't go any farther).
If low cost is an issue and you want relatively high output, I would probably get a DX6090 and then upgrade the emitter with a Cree Q5 or R2 vs the stock Cree P4. Or, I would get the DX11836 and swap out the driver and put in one of the 1050mA 3xAMC7135 linear regulator drivers. Note, however, that this basically forces you to run the modified DX11836 with 1xLi-ion (you lose the wide voltage range of operation). In a SureFire G2Z, 1x17670 should work well. At 3.7V input on a bench power supply (to emulate 1x17670 under load), I measured 1.05A input and a Vf of 3.24V. That translates to a driver efficiency of 3.24/3.7=88%. Thus, about 1/2W of waste heat is generated by the 3xAMC7135 driver. The LED pulls 3.24V*1.05A=3.4W. Roughly 80% of that is waste heat, or about 2.7W. Thus, the total heat generation is around 3.2W. That's fairly low, but I still would put a metal 6P bezel on the G2Z to help remove that heat from the drop-in.
There are probably other equally good, low cost options, but I'm citing only the ones for which I have made actual measurements and feel comfortable to recommend.
