Great progress today. More pictures :naughty:
Starting to wire drivers:
Calculated power to see if I needed additional heatsinking on the MaxFlex. Although my design goal has been for 1.0Amps, these drivers can deliver up to 1.4Amps, so it looks like I will be making these 1xC McG45's a little bit more robust just in case you crazy owners decide to want "more"
So I found out how to get a metal "spring" with thermal AA on both sides to attach to the thermal pad George provided on the MaxFlex:
Before I glued the converter to the HS, I tested it, of course!. As expected, the light came up at its default value of 350mA, which at its lowest level draws 50mA from a 4V supply:
Then glue the converter:
and then glue the HS to the switch:
ta-daaa:
and a quick test using an actual 18650 cell, on its actual host (this LED was for the finned FM 1xC body):
same photo with overhead light off to appretiate the LED being ON:
Then I did the other two 1xC HS/Driver combinations (leaving the 2xC for last due to being quite different):
And that is all for today. More photos tomorrow
Will
