Its the same metal from the negative metal strip that goes up from the switch up to the bulb. I cut it in small pieces and used AA on both sides (one side at a time to let it stay in place).cmacclel said:Someone's busy Whats the AA on the MaxFlex Pad? Metal spring?
The light works fantastic at the 1.0Amp I designed it for. It draws about 2Amps from the 18650 cell which is high but within the normal operating range for the 18650 cell. When I did an extended run at 1.0A on the prototype, the light gets warm, but never hot. I really recommend the 1.0Amp setting, and that is how I am shipping them, but you can manually change the current table to the 1.2A or 1.4A max setting via the same ON/OFF switch. I added a little bit of thermal protection as you can see in the photos above, so you can go somewhat higher, but longevity of the driver/LED will go down the hotter the light runs - its always a compromiseZeissOEM2 said:Hi will.
Like I said earlier.
How bright can I get this without getting trouble .
Yep - that would have worked just as wellcmacclel said:Thanks.....but could'nt you have just of soldered the piece of Mag ground strap to the MaxFlex?
Mac
Icarus said:Great pictures Will! :thumbsup:
Have you seen George's post on the problems with the MaxFlex?
I suppose your MaxFlex's are running fine? :thinking:
Icarus said:I ran a Tri-LuxIII for more than 6 hours at the 700mA drive table without any problem. :thinking:
