Packhorse
There has been some discussion in another thread about building a focusable LED dive light.
I believe this deserves its own thread.
What I have in mind is the use of a SST-50 LED and an aspheric lens, more than likely one of Ahortons which I have had much success with in other projects.
A single SST-50 will provide enough lumen for a really bright hand held light or a not so bright cannister light respectively. In a hand held the burn time will be limited while in a can light the output will not be as great as what other LED clusters could provide.
So what to build? a hand held or a can?
Ideally both! Use the same head that can be connected to a body containing batteries or to the end of an umbilical that connects to a battery cannister.
Biggest issue is how to focus it.
I guess the easiest way is to design it along the lines of a mag light where the head is threaded and turning it moves the lens away from the LED. Since the focal length does not need to change much it only requires a small twist to change focus. This can be adjusted by the pitch of the thread.
Switch.
I think the switch should be twist on /off like the mag solitaire so the same twisting action activates the focus and switch or reed switch based.
Driver.
Driver needs to be able to supply as much current as a SST50 can handle and have at lease 2 power levels. Voltage In should be capable of at least 12v nominal.
Materials
Head should be aluminium. Body should be POM.
I have owned all aluminium dive lights and the W200 which is aluminium head and POM body and I much prefer this setup.
Thoughts anyone?
Switch.
Driver.
Materials
Thoughts anyone?
