737mechanic
- Joined
- Dec 2, 2007
- Messages
- 60
About to build a custom flashlight from scratch. Was thinking of using MC-E or P7 emitter. Going to be made from 1.25 to 1.5 round aluminum bar with as much copper heatsink as I can get in it. I want to drive the LED as bright as I can and be able to run it for as long as possible before needing to turn it off due to heat. If using protected cells would these act as a form of regulator and would the 4.2 max volts be ok until it dropped to the nominal 3.6 or should I still consider a driver due to the possibily of damaging the emitter.
All I want is high and low so I was thinking I could use a simple resistor to get the low. I was thinking of using 3 18650 protected cells unless you guys have a better suggestion.
Also is there a D size rechargeable 3.6 LION battery or should I use the 3 18650's that I was thinking.
Any input and ideas would be great.
