DIY SST-50 P60 module
kerberos0023
Tokyo Japan
I made a P60 module of Luminus SST-50.
http://blogs.yahoo.co.jp/kerberos0023/16019634.html
Thanks! :wave:
hmmm I see secrets....
teh module is definetely extended and that makes me believ that there is one more board inside....
correct?
Hi kenji, looking good....I'm definitely buying if you've got them for sale....solarforce l2p host?:twothumbs
correct?
Hi kosPap,
board is only one piece.
I extend it in a sleeve of the brass and process it.
:grin2:Thanks.
Hi dannyk, :thanks:
:DThank you very much!
Though this is a trial product, I make the same thing if there is a request.
Yes, it is solarforce l2p host.
Thanks.
What's the output and runtime?
The output electric current is 2,800mA.
I think that there is little it, and the fever is standard if it is low or mid for the run time.
But the module becomes the considerable temperature in the high mode in several minutes.
I think that this module had better not turn on with a high mode consecutively.
What is a rough estimate on cost?
and seems like this one might be on the longer side? Thus causing heads to not screw down all the way and leaving gaps between the bezel and body?
I include the EMS postage and regard the price as $ 80.
When it is normal P60, it is around 29mm at full length.
However, this converter is a short spring in the plus pole.
A battery works in a thing of a body.
If there is it in 6P system clone host such as L2P, installation does not have any problem.
I see....but why did you had to elongate it?
It is because a center spring is shorter than a normal module.
On this account when I made a P60 module commonly.
A notice is worthy of the point of contact a battery, and malfunction that it moves in the battery がが battery room, and a mode changes appears.
It is the sleeve extension of that purpose.
you could solder a narrow spring upside down....I have seen it doen several times and the nailbender low voltage modules are the same....
I have done it in another way
