The P60 was never designed to host LEDs. Incan filaments actually "prefer" to warm up to a steady-state condition from a cold start.
So the LED drop in is merely an adaptation. Surefire realized this shortcoming and designed the P60L to drops output when emitter temps get to a specified level.
So the P60 host is far from an optimal LED host. Its more like a compromise design between two different light sources.
The only potted LED drop ins are the Ando and Malkoff. Everything else is not potted. But they all are hand soldered and hand assembled, so theres going to be some quality variation.
Malkoffs are little brick out-houses... little battle tanks, solid and well made. Heres mine which I took apart to re-build. The one on the right I am re-building into a 1.2A - single cell module. Whats not shown is all the thermal potting compound I had to dig through to get to the bare brass. So these little suckers are WELL made.
I broke my swiss army knife blade trying to pry all the potting compound loose.
The build quality of my cheap DX modules is questionable. I own the 0-100, 5-Mode/Memory, R2-3-18V, Q2-5A, and the now ancient BIN P4-3-18V. My favorite is the 3-4.2V R2, it cuts out at 3V so I run it with my unprotected cells worry free. On all of them I reflow'd the solder around the rim. My DX-MCE also needed the same treatment. But they have been as reliable as any of my best lights, no failures from me.
