Excellent find! Id done a few searches to be sure that there were none on there but my searches came back negative - even using some of the search words in the sellers ad. The VSS-3A's are basically 4-sided with slightly rounded corners - your light, my light. The VSS-3's look more 6-sided:
ww.ebay.com/itm/INFRARED-SEARCHLIGHT-FSN-5855-135-0156-MX-8272-VSS-3-28VDC-52A-/151201681006?pt=LH_DefaultDomain_0&hash=item2334528e6e
The control box you got looks exactly like mine and is for the -3A. The front "glass" should be plexiglass. Both the -3A's I've had were/are.
You have no cables, right? I'll find the link to a post here on CPF that has the Amphenol connector part numbers. You'll need to make your own. They will be expensive to buy and make. One fitting is about $125.00 IIRC and you'll need 3. And you will not find the connector fitting threaded ring that fits on the light itself. You can buy the basic connector with a ring but it will not thread on. But that really doesn't matter because the fitting pushes in with much friction and does not need to ring to stay on. You'll need some #4 AWG flexible welding cable for the main power wires to the box and also from the box to the light. There's a bunch of other sizes of wires in the same box-to-light bundle. Lots of soldering involved some with a small torch (the #4's). The one box-to-light cable took me all day to make. And you have to be careful handling the blue plastic pieces of the connectors. They chip very easily. Don't want to paint a bleak picture, just want to give you a head's up that it takes time and money to get the jobs accomplished.
Here's the post with the Amphenol connector info:
http://www.candlepowerforums.com/vb...c-Tank-Light&p=1871898&viewfull=1#post1871898
There is tons of excellent info in this entire thread. You should read it from start to end. It will most likely answer all your questions.
How are you going to run the light - what's your power source? Two automotive-type batteries will fire it up but will not allow the light to perform near it's potential. At best, you'll get maybe 66% of it capability at 24 Volts. You really need a full 28 Volts and 85 Amps to run it (and start it) right.
