Ok, I finally finished modding the SMJ leds in A2, and the result is floody beam with an improvement on the overall output vs MJ(of course, a lot white/brighter than the original leds in SF A2), and I love the tint of the new SMJ as well since it is whiter and cooler than the creamy yellowish tint of MJ leds.
I measured around 208ma current drawn(1.04v dropped across a 5 ohm resistor) for 3 SMJ leds at the tailcap with two 3.2v Panasonic CR123 batteries (around 70ma to each led). And as a comparison to Js measurement for a normal SF A2, he got a measurment of 110ma from a tailcap reading for his normal white SF A2.
The height of how high the led sits in the A2 reflector does play a big part, and I found that generally speaking, it seems to achieve the best 'throw'(or best hotspot lux reading) when the emitter pad is almost flush(or just a hair width higher) with the lower opening to the led.
Also, in discussion with Js in his great A2 thread in general discussion (
The SF A2), I kept on wondering the question--
how much led usage time will cut into(used up) the remaining incan usage time left? :thinking:
Today, I did two experiments, one is to find out when the incan fails to regulate, the V of the battery and the other is how many hours of SMJ led usage time will cost my SF A2 fails to lit up the incan.
For first set of my old batteries(which was originally in my A2 already), I run the A2 with incan until it fails to regulate(or fail to regulate when I turn it off and on), and I measure the V of the battery, and they read around 2.75v each(panasonic CR123).
Then, I put in two brand new panasonic 123 batteries(~3.26v ea) and turn on solely the led on A2, and after each hour usage of led, I would turn on the incan for approximately 5 secs to see whether it will fail the regulation. Then way, I would know how many hours of SMJ led usage will make my SF A2 incan fail to start...
After 9 hours of continuous use of SMJ leds in my A2, the incan failed to start/regulate.(but after 8 hours, the incan lit up perfectly for the 5 sec test). The V of batt reads ~2.645v each. So it probably will be safe to assume the incan will stop working sometime after 8 hours straight usage of SMJ leds.
If we were to assume the incan usage time is perfectly 50 mins, and conservatively, the 8 hours of SMJ leds usage will cost the A2 fail to lit up/regulate its incan...then
my rough educated guess will be for every 1 hour of SMJ leds usage in my SF A2, it will cost approximately 6.25 min of incan runtime.
I will do more testing to confirm about this finding, and
if anyone is interested in helping with the incan/led usage time test for your normal or modded A2, do feel free to let me know. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
