DX SKU 6190 LED Driver, how do I wire this please?
blakelidge
Hi,
Bought some of these for some bike lights I'm building, I have used drivers before (for driving multiple LEDs) and found the wiring on them was straightforward, everything passing from battery, through the driver and on to the leds and momentary switch. However, these little things seem to have a +ring and -ring (mine are the ones marked "AK47")
I've searched a while here and elsewhere and people generally seem to be saying that the batt+ and LED+ both connect to the same point on the driver, I've gotta admit that this confuses me, I'm no Electrical Engineer. So I was wondering if someone would be kind enough to explain where the + and - cables connect and include the correct sequence for battery, driver, switch and LED, a basic schematic I guess.
Thanks in advance
Dave
Just wired up one of these yesterday...
There you are
Batt + and Batt - are connected from the other side of the driver, you just solder a spring on the inner contact on the rear side. GND is already switched through the negative contact of the battery through the switch to the case of the light.
