Re: Eastern power outages (Aug 14)
I haven't seen anyone mention them, maybe they don't make them anymore...but....they used to sell these twin D-cell yellow LED electric candles in Popular Science for around 8 bucks.
My dad loved them because he ran them all night long for 4-6 weeks on a set of D-cells.
Anyway I made him up about a dozen from parts at Radio Shack, they are real simple (three parts) and easy to make. All you need is one of those jumbo 10mm Yellow LEDS, a plastic twin D-cell battery holder, and the appropriate resistor.
I'd drill two tiny holes about an eight of an inch apart on the top side of a plastic battery holder. The LED's wire leads drop in to those holes. Bend the wires towards the battery holder's connections and briefly touch them to the contacts to verify you have the positive and negative going to the correct sides. The LED should light, if not pull it out and flip the LED around.
After you verify, solder one wire from the LED to the battery holders flat contact. The other wire from the LED gets soldered to the resistor and the resistor's other wire gets soldered to the spring connection on the inside of the battery pack. The resistor gets tucked up underneath the spring. The extra clearance needed for the spring gives you enough clearance for the resistor. It's also best to make the solder connections with a couple of dead batteries in the holder. The battery connections on the top of the plastic holder get hot and may start to melt the plastic. The batteries act as a heat sink and prevent the plastic from melting.
LED is held in place by bending the wires to the side, no need to glue it to the top of the battery pack or anything.
That's it your done!
Three parts (plastic battery holder, LED, Resistor) cost maybe $5-$6 Drill or melt with needle two holes and make three solder joints.
Runs for days. Oh yea, the on/off switch is a thin piece of plastic from a soda bottle, you just slide it between one of the batteries it's contact on the battery holder.
GregR
GregR
