EL gauges and inverter question?
vfinterceptor
Hi all,
Just joined and have a question I'm hoping someone can help me with. I'm putting a Chrysler 300 M el guage set in my 2000 Intrepid. The problem is that I have to swap the faces onto the origial cluster electrics in order for everything to work properly. It's pretty much a straight swap, but the Intrepid cluster does not support the inverter for the EL gauges. The inverter off the 300m board has 6 pins and I'm having a little trouble figuring out what power to run to each pin. 2 are easy as they are the output to the gauge faces. I'm assuming the other 4 are power and a reference wire from the vehicles dimmer for the dash lights.
Here is a pic of the circuit board:
http://i40.photobucket.com/albums/e235/gr8twhite/july-09-237.jpg
The boxed dashed line is the inverter circuit where the inverter resides on the board.
The output lines are the two ciruits that come out on the left and are labeled output on the print.
I need to identify the other four inputs to see if I can source the power and control from the stock intrepid circuit board.
Thanks for any help
Cheers
BJ
