Re: ENLOOP DISCHARGED COMPLETELY
Hello Sanyo.Eneloop,
Welcome to CPF.
Over discharge is not the best thing to do to NiMh cells, but sometimes they will recover with minimal loss.
After sitting a few minutes, check the voltage again. You may find that it has increased to over 1 volt. If that happens, charge normally.
If the voltage does not increase, you may have to fiddle a little to get a charger to recognize it and start the charging process. If the charger does not recognize the cell, you may have to recycle it, unless you have some advanced charging equipment available.
You can throw it in the charger and see what happens. There are no additional safety issues involved with trying to recharge a cell that has been over discharged, but there may be some additional heat involved, so I would stick to the lower charge rate that charges the cell in 2 hours rather than going for a 1 hour charge.
Tom
