Looks pretty interesting.
Too bad minimum
input voltage is 3v dc, and maximum output
current is 20ma. Might need a driver
transistor in order to overdrive the led's
a little for increased brightness.
Maxim makes similar chips, but are priced
around $4 each. If that price of 81 cents
stands for normal production(as well as samples), they might be useful in 3 cell
flashlights. The 3v input requirement doesnt
impress me though. I think they could
have done better
It might be possible to use a simple switching supply to supply that chip.
That way it can get its 3v input.
I suspect that requirement is needed in order
to drive the output MOSFET gate, so its probably a low current requirement too.
If so, the output transistor might be able
to run from much lower voltages while the
main ic gets its 3v requirement. Of course
the circuit will be much more complex, but
it might be worth it after all. I guess
we will find out when they post some
application notes. Ill check back now and then.
--Al
