Golden Ears
- Joined
- Jul 6, 2017
- Messages
- 5
For me The size of the flashlight was perfect, I really like the beam pattern and even Corona. I like the size and cost of the rechargeable batteries. I like the durability of the Sapphire lens and the exotic coatings to the outside which prevented scratching as well as the trit in the base.
Err..my only omplaint was you could lose a head from unscrewing it too much. That is how one bit the dust.
I also owned a Drake but preferred the run time and easier to hold size of the Draco. The Drake got a bit too hot if held in the mouth because the lamp was too close.
i don't want a less bright light, a larger light, one made of inferior materials, one without a trit, worse beam pattern, non rechargeable batteries , fewer selectable light levels, non sapphire lens, or cooler beam color...any of those things would be a step backwards and frustrate me.
thank you in advance if you bothered to read this far.
Experts out there.....does anyone make something better with as nice or smoother beam pattern?
