d'mo
My wife is from The Philippines. I frequently send/take lights to my in-laws, but since batteries can be expensive and the environment is VERY unforgiving cheap flashlights don't fare well. I've seen the salt air dissolve UN-anodized Aluminum, tin, cheap stainless steel, and corrode fresh batteries, all within a few days. I've even seen mold to grow INSIDE video cassette housings over night and fire ants get inside "sealed" containers. The heat has caused many a battery to leak, killing dozens of Mags. I've been searching for the ideal flashlight for extreme conditions, but have yet to find one.
The Arc-LS might do well due to it's ability to accept commonly available AAs, durability, finish and light output. Another possibility is the Free-Light, but it's lack of a constant-on switch and lack of waterproofing is unfortunate. Because the housing is black, it might also warp when exposed to the direct equatorial sun (no joke, I have video of a thermometer struggling to go above it's 125 degree limit).
So far, the Arc-AAA and Free-Light are the top contenders. Does anyone have any other suggestions?
The criteria:
-Cheap, commonly available batteries or solar (preferred).
-Casing that won't warp when exposed to extreme heat.
-Casing/components that won't corrode, even when expose to salt water.
-LED (no maintenance)
-Waterproof.
-Small size.
-Bright enough for minor trail negotiation.
Thanks!!
The criteria:
-Waterproof.
-Small size.
Thanks!!
