I just received a P2d CE in a trade and like it quite a bit. I had issues getting it to switch modes at first, then it worked, now it won't.
I tighten both ends all the way and turn the light on. It's on max power. I press the tailcap halfway and it's max power strobe. I loosen the light end bezel until it comes off and at no point does it switch off of max power mode. I try loosening the bezel with the light on, with the light off, I try tapping the tailcap halfway after loosening it some etc. No combination of these actions has gotten me anything but max power and max power strobe.
I've tried searching for threads covering this problem and saw some stuff about the battery type possibly affecting similar light models, so I thought I'd specify that I'm using an Energizer Lithium photo battery that says on the side +123 3.0V Pile Lithium Battery
