FENIX T1 CE TACTICAL LED Flashlight
Tempora
Greece,Thessaloniki
I have searched but no results have appeared so I have created a new thread.
The first Tactical Fenix Light
• Cree Premium (Q5) 7090 XR-E LED with lifespan of 50,000 hours
• Two modes of output, selected by turning the bezel:
• Turbo Mode: Constant 225 Lumens, 1.5 hours
• General Mode: Constant 60 Lumens, 10 hours
• Highly efficient focusing head - throws beam over 200 meters
• Digitally regulated output - maintains constant brightness
• Low battery indication system
• Uses two 3V CR123A lithium batteries
• 13.65cm (Length) x 3.5cm (Diameter)
• Solid stainless head & durable aircraft-grade aluminum housing
• Premium Type III hard-anodized anti-abrasive finish
•153-gram weight (excluding batteries)
http://www.qualityflashlights.at/termekekmain.php?csoportid=58#83
• Waterproof to IPX-8 Standard
• Toughened ultra-clear glass lens with anti-reflective coating
• Tactical tailcap switch with momentary-on function
• Tactical body clip – attaches securely for easy carrying
• Anti-roll, slip-resistant body design
• Able to stand up securely on a flat surface to serve as a candle
• Included accessories: holster, lanyard, two spare o-rings, a rubber switch boot and 2 x CR123A Lithium Batteries
