I've got these...special just for you
I'll conceed the I.S. is accurate, that your using it correctly and that it's indicating the figure you say that it is but if that figure is indeed 225 lumens then something else is missing in the equation. just out of curiosity what was the lumen reading from the Integrating Sphere after 60, 90 or 120 minutes of run-time?
It's not that you're giving us a wrong output number...at this point I'm only questioning it's usefulness. We're not getting any additional information or asking if the manufacturer should even make that claim in the first place. If the TK11 can't maintain the output for it's stated regulated run-time then these facts should be discussed.
The TK11 is stated to produce 225 lumens presumably out the front, for 2.7 hours with an 18650. Since all of these lights use the same batteries and the same emitters, one of them isn't going to magically stand out as having output or efficiency far superior to anything else available. For 225 lumens to come out of the front of a nickel reflector and multi-coat optic it's going to require about 280 lumens at the emitter which requires about 1.25A. If the light is indeed pushing 280+ emitter lumens then it's not going to be able to maintain that level of output for long. If this is the case then it does put into question the TK11's claim of 225 lumens since it doesn't mean much if it can't maintain than output for a reasonable amount of time.
Although it's interesting to read about a test that someone did on a $10,000 I.S. it actually provides us with less meaningful data than someone with a light meter, timer and graph program. I think the problem that I have with claimed output figures is that the manufacturers don't tell us how they arrived at the figures. For example if a light has been measured at 225 peak lumens, then perhaps it should be stated that they're
peak lumens. If a manufacturer as taken the time to measure a light's output througout it's runtime and then averaged the output figure, then I wish that they'd state that figure as
averaged lumens.
