The official release from Fenix ( http://www.fenixlight.com/viewnproduct.asp?id=79 )
• Cree XP-G LED (R5) with a lifespan of 50,000 hours
• Uses two 3V CR123A Lithium batteries or one 18650 Li-ion battery
• 135mm (Length) x 25.4mm (Diameter) x 34mm (Head)
• 152-gram weight (excluding batteries)
• Digitally regulated output - maintains constant brightness
• Reverse polarity protection, to protect from improper battery installation
• Tactical tail cap switch with momentary-on function
• Anti-roll, slip-resistant body design
• Premium Type III hard-anodized anti-abrasive finish
• Toughened ultra-clear glass lens with anti-reflective coating
Notice: The above-mentioned parameters (tested in lab by using quality CR123A primary Lithium batteries) are approximate and may vary between flashlights, batteries, and environments.
** 18 hotlinked images deleted - Kestrel **
