Ven? Which TK75vnQ is the way to go: floody or thrower?
Spec 2 or Spec 3?
I want the 14k out the front with 500k throw and according to an e-mail exchange with Vinh, that animal doesn't currently exist so I have to choose. Suggestions?
(I'm still waiting on the refund checks)
Does cost come into it, #2 is $320 and #3 is $500
#2 throws further with lots of flood at close to 400kcd and 5000 ish OTF lumes
#3 is now 16,000 OTF lumens due to carrier upgrade they all get(removes the polarity protection, so extra EXTRA care to be taken inserting cells!!!!!)
As i have throwers and flooders its a tough one, i chosethe Q70 over the Q for a couple of reasons. Near 200kcd is enough for me , flood is more useful over throw for me, i love the xhp70 leds!!! they are awesome!!!!
Carrier mod to aid current flow
4x xhp70
Heat treated and engraved bezel, just for personal touch.........love it
and strap attachment and use for tri pod attachment
Make sure which ever you get, get it engraved, just for that personal touch and being special its worth it( to me anyway)
Now generally and all things considered i would recommend the tk75vnQ as for the throw and good flood, awesome do it all light.
For a HUGE wall of light, then the Q70 version, if feeling flush and want 20,000lm+ then the Q77 with 7x xhp70 leds,however its "only" 11,000cd and $1000
If you want 6000+lm and 550+kcd, the x60vn is an option to check out, like a next step up in performance over the tk75vnQ...........not quite the build quality, still good,takes 6 cells over the 4(well unless you use run time kits with the TK!!!)
So what is your preference?
Poor beam pic as used phone so the brightness completely overwhelmed the phone and dims it down, not to mention poor conditions due to mist from the lake
TK75vnQ70
The phone just cant get the brightness, nor the flood.........trust me its bright flood!
If lumens matter, you like a wall of light, enough reach due to sheer output, amazing flood to light a field up,the Q70
If (5500lm is not to be sniffed at)lumens are not as important, adequate flood but a bright large hot spot with great throw is, then the Q version. Think tm16gt on steroids!
Bare in mind, example, nitecores lumen claim will be more than likely LED lumen(not 3500 OTF), vinhs are conservative (OTF) Out The Front lumens, can loose 20-30% from the LED lumens due to reflector/s/ and lens................
So 5500 OTF is maybe around 6500-7000 LED lumens!
Cant tell you which, just food for thought and if not happy with choice, vinh does offer money back or exchange.............he is awesome to deal with mr quack
Make sure drivervnx2, so you have the flexibility of various groups, be it starting in low, or with memory, 2 modes or 5 etc............enough to suit you!.Quick change on the fly, and in another group with different modes...............fantastic.
I like good do it all type lights as generally more useful than a pencil beam, or just pure flood. However its good to also have dedicated lights for each. Awesome flooder, and an awesome thrower...............
Loving the tn32UTvn at 400kcd+, pretty amazing and great build quality. Flood covered many times over as a preference, mm15vn,tn36vn,tk75vnq70,CQvn off top of head
Dont rule out the k60vn, amazing light,230kcd with one of the best beams imo, stunning, not to mention the great control ring UI!!!!
Wow thats some waffle
Edit- 110kcd now due to diffused domes, maybe similar to the tm16 but a lot brighter and far more flood
