Zero_Enigma
Ok all you CPF geeks and freaks out there with your crazy lights! I just joined the ranks of being enlightened by the joys of solding my first SSC P4's thanks to my mate that got them from Deal Extreme.
He actually made a 3xCree w/3 degree lenses mounted on the reflector hole on his bike. I'll see if I can get a photo later if he's willing for me to snap a photo of his setup. Damn that was BRIGHT!
Ok, so I was talking about some field kits before for some quasi-cyber punk on the side of the road/park soldering but did not know what kit I needed to get. Obviously a soldering iron is needed for sure. Not sure if I should go with battery or butane. Pending price I may carry both so I can cover both grounds. Are those battery soldering irons safe to use with NIMH or lithium batteries?
Also I would like to see input from people for 2-3 types of field kits: BASIC, ADVANCED, and PRO (?)
This is what I can think of right now. Please contribute ideas in this format below:
BASIC:
-Soldering iron (batt or butane)
-multitool (Should be EDC)
-solder
-solder wick
-spare wire (rolled up CAT5 cable)
-spare LED?
-DMM (pocket/compact)
-spare regulators? (if using the cheap ones. I blew one up tonight >_<)
-thin latex or thin gloves should you be concerned about the lead in solder (this may be an ADVANCED option but you may already have a pair tucked into your bike repair kit if you've ever worked with your chain you'll know why to have a pair handy )
-cable ties (couple thin and midsize to cover all grounds and you can end to end to tie larger areas)
-electrical tape (improvised shrinktube cover)
-rubberband (many uses, Thanks PeLu)
ADVANCED: (Everything BASIC plus the following)
-pliers
-stripper
-side cutters
-LED lenses
-shrinktube (Thanks PeLu)
-silver solder (Thanks PeLu)
-quick connectors
PRO: (Everything BASIC & ADVANCED plus the following)
-folded up 'helping hand'
-solder pump
-spare butane fuel for butane solding iron
-special low temp solder for sensitive work (Thanks PeLu)
-compact quick AA/AAA battery charger (prefer with fold up plug, if not then thin cable. NO cube plugs. I've been told this should be in the BASIC but when I thought about it if you're using a AA soldering iron you can buy cells at any store and not worry about being out of power without carry extra fuel like the butane if you want out of fuel and bought a refill can and have to carry the extra weight)
Thats all I can think of right now. Thanks in advance for any help.
I'll update the list in the top post as more info comes in. For those with experiance in kit sorting perhaps you could help out with what should be placed in BASIC, ADVANCED, and PRO. Thanks.
BASIC:
-solder
-solder wick
-spare LED?
-pliers
-stripper
-side cutters
-LED lenses
-quick connectors
-solder pump
