The design voltage of the Lumens Factory M4 lamp is 9.2V only, that's way less than 10.8V so it will be overdriven severely by 3X Li-ion cells.
The fact, it survives this torture is again a proof of the durability of Lumens Factory lamps!
Where to get a Pila IBC charger? If you are in the US, you should find plenty of online stores that sell it.
If you still use those expensive CR123A batteries in your M6, it is time you immediately buy a 2X 18650 holder
For the price of maybe one charge, you'll get this holder... then add some Li-ion batteries and you really start to USE that excellent M6! It just deserves to be used more frequently
Again, make sure you buy the AW 18650 2600mAh batteries if you plan to use the more powerful 2-cell lamp options. For example, the really bright WA1111 lamp can be powered by this battery... and NOT by those cheaper deal extreme Trustfires... they switch off immediately, letting you think you did something wrong, or blew the lamp....
The same may be true for the 3X 17670 setup. At least, the highly appreciated Lumens Factory HO-M6R works excellent in combination with three AW 17670s in an appropriate holder...
Timmo.
Timmo.
