I've just used Modamag's excellent tri-star heatsink to modify my police issue 3c Maglite, with three Seoul P4s driven by a shark driver. I used 20m reflectors and UCL AR glass. It all fitted together very easily.
Dismantling the maglite was simple with reference to the ROP guides on candlepower...thanks guys! I would never have worked out that the switch was removed using an allen key through the centre of the button.
http://picasaweb.google.com/julesboz/Magmod
Once the switch was out I removed the sliding lamp holder using an allen key on the little brass bolt on the side of the assembly. Soldered wires direct to the switch outputs:-
<a href="<A href="<A href="http://picasaweb.google.com/julesboz/Magmod/photo#5072249813433887650"><img">http://picasaweb.google.com/julesboz/Magmod/photo#5072249813433887650"><img">http://picasaweb.google.com/julesboz/Magmod/photo#5072249813433887650"><img">http://picasaweb.google.com/julesboz/Magmod/photo#5072249813433887650"><img src="http://lh5.google.com/image/julesboz/RmRAVNXEq6I/AAAAAAAAABU/q7OYWhFISNg/s144/DSC_0022.JPG" /></a>
Home made thermal epoxy fixes the shark driver to the back of the heatsink:-
<a href="<A href="http://picasaweb.google.com/julesboz/Magmod/photo#5072251789118843858"><img">http://picasaweb.google.com/julesboz/Magmod/photo#5072251789118843858"><img src="http://lh5.google.com/image/julesboz/RmRCINXEq9I/AAAAAAAAABg/EZDc16XjywE/s144/DSC_0020.JPG" /></a>
Three Seoul stars sit on top with a smear of thermal grease:-
<a href="<A href="http://picasaweb.google.com/julesboz/Magmod/photo#5072249843498658738"><img">http://picasaweb.google.com/julesboz/Magmod/photo#5072249843498658738"><img src="http://lh4.google.com/image/julesboz/RmRAW9XEq7I/AAAAAAAAABY/Io_S-vswc-8/s144/DSC_0012.JPG" /></a>
Screw it back together with the new glass:-
<a href="<A href="http://picasaweb.google.com/julesboz/Magmod/photo#5072249873563429826"><img">http://picasaweb.google.com/julesboz/Magmod/photo#5072249873563429826"><img src="http://lh3.google.com/image/julesboz/RmRAYtXEq8I/AAAAAAAAABc/LPkKJ1fUdeE/s144/DSC_0024.JPG" /></a>
Two protected 18650s fit inside with a lining of 3mm foam:-
<a href="<A href="http://picasaweb.google.com/julesboz/Magmod/photo#5072249796254018450"><img">http://picasaweb.google.com/julesboz/Magmod/photo#5072249796254018450"><img src="http://lh5.google.com/image/julesboz/RmRAUNXEq5I/AAAAAAAAABQ/tj3vww_5Big/s144/DSC_0012.JPG" /></a>
The tailcap spring needed stretching by about 3mm to make firm contact with the batteries
Draws 1.09A from the cells at 8.4V
The end result: amazing beam, like my light and motion HID, perhaps even brighter. I'm deligthted.
