hi,
i will present the first bridgelux mod here on cpf. i used the bigest available emitter with 2000 lumen output.
host is a ultrafire rl-2088 wich is originaly with a six die ostar. there are three 18650 lions for power. here some pictures from my mod and what i did:
first disasamble all:
some work with my lathe - yes baby this lathe is about 80 years old, but it do the job like charm:
glued the emitter on the base:
test if it seat right:
check the reflector seat:
now the difficult part. modding the boost driver. in its original it will give 800mA to the led, but this is not enaugh for the bridglux. to get 2000 lumen it needs 2000 mA @ 16,x volts:
to get the power i need i done some things: change the orginal fet against 2 high power fets from a comutermainbord (there was a second place on the pcb). these fet´s can push high current to throu the coil. add a second condensator, change the feetback resistors and the diodes. now the driver ushed 2200mA to the emitter:
so here some shots inside the reflector. this picture is heavy underexposed so we can see the 25 dies:
another icture i litte brighter:
again:
the complete setup:
at low mode:
i will take some beamshot these days. this flashlight is a real floodmonster!
markus
again:
the complete setup:
at low mode:
markus
