Flashlight Aficionado
- Joined
- Jul 12, 2006
- Messages
- 834
I have found an image of the Chip Weevil.
So if you see anything like this, anywhere near you house, you are in big trouble. My sources (no name agency) says the only way to kill the Chip Weevil is to electrocute them. Now this can kill your beloved LED flashlight.
So you have to make a trail of phosphor leading to an metal plate. The Chip Weevils(CWs) will have to eat all the phosphor in the LED before they look for the new food source. There are some quick calculations. If your LED is dimming slightly, give the CWs 24 hours to migrate to the metal plate. If your LED flashlight got really bright and suddenly died, your Chip Weevil problem is solved. They accidentally ate some of the diode and electrocuted themselves. Now you only have to replace your LED. If your LED is very dim, 5 hours is enough time because they have almost eaten all of the phosphor and will quickly follow the phosphor trail to the metal plate.
When the time is up, electrify the metal plate for no less than 10 seconds. DO NOT electrify the plate before then. A: The phosphor will be vaporized and the CW will not go where there is no food. B: They stay away from the current. Now that the Cip Weevils are dead, just replace the LED.
You probably surmised that the Chip Weevil does not feast on running LED. They only feast when it is off. So if one of your lights has a Chip Weevil infection, turn on all your flashlights. Yes even the incandescents. The incans won't be damaged by Chip Weevils, but they are carriers.
