GlimmerGirl
- Joined
- Oct 25, 2010
- Messages
- 3
I am a new home owner and looking for a flashlight, i had no idea there are so many. So any advice is appreciated. I would like to be around $30, maybe $40. I would like to buy from amazon, because i have some credit there. I have an old maglight, but want something smaller that i can also travel with. i will answer the questions below, thanks in advance for any help!
I saw these at amazon but now i'm overwhelmed with all the choices!
http://www.amazon.com/gp/product/B001GAOO9G/?tag=cpf0b6-20
http://www.amazon.com/s/ref=bl_sr_hi?_encoding=UTF8&node=228013&field-brandtextbin=MagLite
Amazon.com__
2) Budget: An easy question, but you may change your mind after answering the rest!
____Less than $30.
____I'm flexible, tell me what you gotJ.
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
I think right around 4 inches, maybe the kind that take 2 AA batteries
____Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
5) Emitter/Light source:
____I don't know, whichever is brighter.
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
I can use recharcheable or regular alkaliine
____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today's most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
I would like as much light as possible within my price range
____I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
________5-20 yards/meters (check out a noise in the backyard)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____90-120 minutes (Runtime is moderately important, but still not critical)
12) Switch Type and location (choose all that apply):
____I don't care.
____I don't know.
These are not very important but would be nice
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don't care.
____I don't know.
14)Material/Finish/Coating
____I don't care. metal, not plastic
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
None
Amazon.com__
____Less than $30.
3) Format:
6) Manufacturer:
____I don't care.
____I don't know.
____I don't care.
____I don't know.
None
