hi, all.
this project is a continuance of 'DIY SST-50 focusable U/W light'.
but ive changed & advanced its concept and now im building the parts
based on the new concept. so i make a new thread.
concept diagram
(clicking fig shows large one)
As shown in the figure, this light is a sort of 'modular light system'.
a newly added concept is separation of 'modify light path' part from
an emitter and this part is exchangeable as a lens in SLR.
actually im building a focusable light with transparent acrylic pipe.
this avoids vignetting of wide angle beam by opaque body tube.
my preliminary experiment showed the very tight and very wide beam
but a bit ugly lighting pattern on the wall. i think this is not issue in the real world.
i dont dive so frequently that i want to use the light both under water and on land.
Heat may be the main issue in its use on land. The acrylic pipe & box may
be soft by heat. this is why ive been building a light controller to monitor & control
the heat production. and ill use a junk CPU cooler on land.
depending on the progress, ill report the results.
but first i have to watch the world cup on TV for a while.:party:
thank you.
concept diagram
thank you.
