Waterfish said:Do the holders have the same effect for AA rechargeables? I have heard about the rechargeable CR123's having a few more issues than rechargeable AA's.
I'm unsure if modamag is using a new design, but I'll have Raymond shoot him an email addressing any issues. Thanks for bringing it to my attention.
cmacclel said:I forgot you where using AA's You won't have to worry about the CR123 issues but still the circuit does draw current. I have one of Modamags regulated CR123 holders and the boost circuit does draw current at all times. I didn't realize this at first and left a set of new CR123's in one of Mini-HID's, 3-4 days later they barley lit the lamp. There just like Georges Nflex, D2DIM type boards. They have a sleep mode but still draw current when not in use so the battery's must be removed from the circuit.....and if that circuit is incorperated into the holder then the batteries have to be removed from the holder.
Mac
PoliceScannerMan said:Mac do i need to take out my batts in between uses?
PS sorry to be OT
Waterfish said:Just to clear up any worries that people are getting, the non regulated battery carrier that is included with the magHID right now do NOT drain and run out when not in use.
The batteries will only drain with the light off with the REGULATED BATTERY CARRIER, which is not yet available.
CHC said:Hello AlanH!
You're going to really like this one when you get it. Seeing it is something, that's why there's a fascination with this thing. That Streak of Beam through the night sky is awesome. And I'm talking about a HID light for its size and not in comparison with other HID such as Acro X990 or Costco/HF/ChicagoEPT HIDs now. . .
Enjoy When You Get It!
AlanH said:. . .if I touch the tailswitch, even slightly, on purpose or inadvertantly, it goes off, how long am I supposed to leave it before I turn it on again?
AlanH said:What is the approx runtime when loaded with it's 8 x 2300 AA's ? Using it in ten minute bursts.
CHC said:That also happens to mine too. You can turn it on straight away if you wish, but I don't make this a habit. I've learned to be cognizant of the "sensitivity" of the tailcap switch.
Don't know about using it in 10 minute burst. I am using DURACELL/Energizer 2500mAhs and they run on continuous for ~90 (+/-5) minutes. I get similar results with alkalines also.
By the way! Congratulations on your acquisition Alan!
Enjoy!
