I'd like to go for the rechargeable route for one of my G2's. I have been reading around but the amount of information makes my head spin and I can't find a specific thread on a G2 host with my preferences below.
My priorities are a stock G2 host which means keeping the lexan window and practical runtimes:
1. what sort of incandescent bulbs can be run without melting the lexan window?
From LF, I assume that these bulbs are safe: HO-4, EO-4, and ES-9 as they are within the P61 lumens rating that SF says can be run in a G2. Appreciate if anybody can confirm if these are ok and if I can stretch it to a SR-9?
From Streamlight, can either the strion bulb and the TL-3 bulb in a FM adaptor work?
2. what sort of runtimes will I get from the lamps above using:
AW protected li-ions (either 2x16340 or 1x17670) in a compatible bulb above?
and, of the bulbs I mentioned above only the ES-9 has a current draw of less than 1A, will all of these lamps benefit from a LiMn chemistry? What sort of runtimes will I get with LiMn? Finally, what will happen if I use a LiMn in an ES-9.
Thanks in advance.
Thanks in advance.
