kramer5150
I've been using a little Gerber Tempo for a couple weeks, so I thought I'd post up some impressions...
Cheers-
-Cheap, $10 B&M availability from REI and Sports Authority stores.
-Good regulation for 6-7 hours, output tapers off as cell completely depletes. No abrupt cut off.
-Robust construction and smooth anodize finish.
-Smooth floody, night vision preserving 7-8 Lumen beam from Nichia-CS.
-Faint-blue colored hot spot with some warm yellow tint side flood.
-Runs equally-well with standard AAA NiMH or Alkaline.
-Switch activation feels solid as the cap is twisted, no "spongy" feel.
-Smooth threads and tailcap O-ring.
-Solid feeling twist-switch, that can be used as a momentary switch.
-Spring contacts at both + and - ends to maintain battery contact.
Jeers-
-Anodize scratches very easily.
-I question my particular units water submersibility. I can blow air through the front of the light, indicating its not completely sealed. Although I do think its sealed well enough for anything less than a water-dunk.
-No lanyard included.
-Questionable build quality from unit to unit.
Overall I am happy with this little light. Its not something to WOW everyone around a camp fire, its more a night-vision preserving utility tool. I find ~7 lumens just about right for this kind of application. Its bright enough to illuminate the ground 7-10 feet in front of you, or gently illuminate a room with night adjusted vision. Its gentile output will not leave you blind with night dilated vision.
The first unit I bought from REI, had an off-center aimed emitter and developed a flicker condition. So I took it back and exchanged it for the one you see here, which I more carefully picked for its centered emitter. So, while I am happy with mine, I would not recommend purchasing one on-line. Local B&M I think is the only safe way to acquire one of these.
Heres my video review:
http://www.youtube.com/watch?v=6nHrLU6VfN4
Here are some pics:thumbsup:
The tempo runs off a single AAA, the AA battery is pictured below for size comparison only.
Cheers-
Jeers-
