Morepower!
Ok I found out the hard way(don't ask) that the frosted finish on the Microfire Warrior's reflector is some type of a paint like coating which can be sanded back and polished. After doing mine (see pic) it now puts out quite a bit more light, was putting out 53,000Lux @ 1m, now puts out 92,000Lux @ 1m. Just a warning though if you decide to do it it's not an easy job because they have sand blasted the reflector first in order to get the coating to stick. And this means LOTS of sanding before being able to buff it. I used a dremel with a 30mm buffing wheel and some Autosol, though the proper buffing compound for aluminium would probably be better. I'm going to get some and redo it later. Note that the pic dosn't do it justice, it really is a mirror finish now. The only drawback that I can see with this mod is there are now some artifacts in the beam, this dosn't bother me though as I'd rather have the extra light ! Just thought I'd share with those that can't leave things alone like myself.
I also have a question, should these lights flicker slightly ? Mine seems to flicker, shifting slightly to red and back again almost constantly. Could it be a bulb problem ?
