Nanomiser
Hi Az Tiber,
I'm okay using primary batteries or rechargeables; whatever works best for the application.
Besides the high drain, are there other reasons to use recharchable batteries with the HO-M6R lamp?
Thank you Az Tiber & JNewell for the source suggestion; I will be buying the lamp, protected rechargeables and charger from the Lighthound.
Which charger would you suggest for the RCR123? I am also looking for a charger to work with FM's 6 X 17670 holder.
Nanomiser,
That bulb is also available from Lighthound, a merchant very well-respected on this site, as well as from the manufacturer Lumens Factory, who is also very well-respected here. I don't know much about their M-series bulbs, but I can vouch for the quality of their E-series bulbs.
However, from reading its description, that HO-M6R lamp is meant to be used with rechargeable batteries - is that you're looking for, or do you want a replacement that runs on primary (disposable) batteries like the original lamp?
