Flashlites R Us
- Joined
- Oct 19, 2009
- Messages
- 41
A couple of hours earlier this evening I had to go outside.
When I tried to turn on my Thrunite Catapult it kept turning off AFTER the switch would return to it's release position. After about 5 tries of complete forward push and release it finally stayed lit on high and all the other settings (including click for off) were working fine when I tried them. Back in the house I threw the light on my bed.
Somewhile later my wife says "whats that bright light from down the hallway".
So I walk into the bedroom and discover that my "CATAPULT" HAD TURNED ON............ON IT'S OWN
I picked it up....... YYYYIKES the entire light was so hot that I could not hold it firmly for more than a couple of seconds before shifting my grip (great heat transference).
Being quite cold here I quickly placed it between the double front doors to cool it down a bit.
When the light was just warm to the touch I removed the batteries and they EACH measured 3.5 Volts. Obviously the light had been running in the high mode for more than an hour. I put in 2 freshly charged 18650s and the light so far works normaly.
As I recall this glitch (NOT STAYING ON) has happened once before.....BUT it has NEVER turned on by itself.
I don't want to think what might have happened if the lens had been pressed up tight against the comforter/or headstanding on my wood floor.
This seems to be a fault with the tailcap switch which I will test tommorow. This leads me to wonder why Thrunite includes a spare switch with the flashlight??????????
Any comments on testing the switch or any thing else would be appreciated. I am now going to bed.............but not before I REMOVE the tailcap because it can still sometimes complete the current path through the anodised threads themselves. I've tried this WHEN I FIRST RECEIVED THE LIGHT.
