I have some numbers that I measured myself. Standard caveat applies here, as always -- my meter is a reasonably cheap light meter that I think is fine for this usage and tends to jive quite nicely with numbers tested on much nicer equipment and/or published by manufacturers, but
it is not a NIST-certified meter. Wish I had one, but I don't. So take all these numbers with a grain of salt, so to speak:
Light / Emitter | Tested Lumens | Candela | Throw |
HCri200 (stock 200 lm 219b) | 204 | 3000 cd | 110 meters |
HDS 250 (stock 250 lm Cree XP-G2) | 252 | 4500 cd | 134 meters |
Modded - Nichia 219b SW45k | 198 | 3000 cd | 110 meters |
Modded - XP-L HI 3D | 322 | 6200 cd | 157 meters |
Modded - Samsung LH351d | 360 | 2900 cd | 109 meters |
Ra GD170 (Osram Golden Dragon) | 160 | 4100 cd | 128 meters |
A few things to note:
- I included the tested lumens numbers so you could get an idea of how my cheap meter lines up with HDSs good equipment, so you can formulate your own "correction factor" for my numbers or whatever you need to do. Plus it gives you a baseline for the modded lights which are unique.
- The Stock Hcri200 219b and my modded SW45k 219b read almost exactly the same. That's to be expected but just wanted to highlight.
- I don't have numbers for a stock 325, never tested one. Sorry.
- I also don't have numbers on any of the official Nichia 219c runs, like the High Noon or 3 o'clock high. I didn't get in on those. But since they're very similar in size to the 219b and also tuned to output 200 lumens I'd expect very similar throw numbers as well, so I think 3000cd/110 meters is a safe estimate on those.
- The Ra Clicky is just included as a reference point, and maybe an illustration of how beam shape effects these numbers. That's the lowest lumen light on the list but far from the shortest throw distance. In fact it makes less than half the lumens of the Samsung but easily out-throws it, because its tiny and produces a narrow beam.
So I'll leave it at that for others to draw their own conclusions about the possible performance of the XP-G3. I don't have much experience with that emitter so won't be any help there. Sorry.
