No, the rotary is perfectly regulated on both, and will give you the same output, minus of course a few % of variation if you measure it with a luxmeter.
Great info thank you sir!
Wow congrats Wimmer! Glad to see you so happy with it. Next on the list is the Boss 35?
Having been able to sample both the Boss 35 and a HDS rotary is the last couple weeks, I have to say, I actually liked the Rotary better! Granted the Boss has a better clip and is brighter, but the 325 rotary that I compared to my Boss 35 Nichia 219, seemed almost as bright! The beam just wasn't as full. Both are nice lights though!
I'd really like to compare the 325 4k with the 200 high cri.
You should lend me yours.
And I found the same thing on the boss. The concentrated light on the rotary because of the reflector really lights up a lot. Though the triple lights up a much, much larger area.
I just love the rotary.
It has arrived
No problem! Here it is:
http://www.oveready.com/b-o-s-s-/boss-35-clicky-7075-patina/prod_442.html
It's unquestionably the most sought after light right now lol.
Any news yet from the SHOT Show? I'm anxious to know if Henry has anything new!
If you don't mind me asking when did you initially place your order
Thanks
I can't get over how low the lowest setting is... has to be a world record low. It deserves it's own name too because firefly don't even cover it.
Congrats on the Rotary! It is a great light. The low, which does pretty much everything that I need a low to do, isn't even in the "Top 5" of low level output. There does become a point of diminishing returns personally, but there are lights (005, 007, Tri-V, etc.) that can go low enough to make a single trit look bright.
Wow I would not have guessed. This low is so low I can't see the beam on the wall from my chair with the lights out. Yeah I wouldn't want it any lower... this is nice though.
There used to be a whole group of CPF'rs into sublumen outputs, but except for @reppans occasionally, I don't see most of them around anymore ....
It's not really a huge interest of mine, but I do have lights so low that you can't even really see the output shining on surfaces just a few inches away, but you have to actually stare straight at the emitter to try to see if it is on or not :shakehead
I appreciate sublumens, and stunningly bright output as well, but I have found a love and desire for merely low lumens, 4lm, 8lm, 15lm.... 25lm is too bright once my eyes become dark adapted.
