ElectronGuru
Regarding UI:
I guess that if HDS could marry these 2 concepts to some degree
Regarding LED choice:
the most important choice for me today regarding the LED in expensive lights is that it is upgradeable. Preferably by HDS and not by only modder's on CPF as that will void the warranty.
Excellent points. I want to expand on these ideas and add one of my own.
1) UI:
Since seeing the HDS EDC for the first time, the 'waist' (tapered mid point) has been screaming at me - DIAL. An infinite adjustment dial (ala SF Titan) sounds ideal and intuitive, but how ideal is it to have your output changing up or down inadvertently while you're using it?
What I have in mind is slightly less wow, but more functional. A dial (head, middle, or tail) with 5-7 fixed notches. It could operate by itself (0, 1, 2, 3, 4, 5) or in combination with an on/off tail switch (1, 2, 3, 4, 5). Used with a tail switch, you would twist to the desired level (works in the dark) and then switch it on. A proper tail switch would also allow momentary continuous on for every level. Make the notches programmable, with addresses instead of fixed levels, and you can make the ideal lineup you want. Call it the HDS Ratchet.
2) LED
Buyers remorse is big. Obsolescence is bigger. How about a design with changeable heads. A new LED debuts and instead of buying a whole new system, you buy a new head. It has a new engine, reflector, and housing, tailored for the new bulb. Owners can decide when the new head is worth buying, given the extra performance. Offer an exchange program for the old head, which is then recycled with new internals.
3) Platform
How about a flashlight system, even more Lego than the original HDS. Choose the head you want, choose the dial, choose the battery body, and choose the tail. Buy one of each and change it around as the mood strikes or the environment demands. One platform supporting 3 or 4 battery sizes, fixed or programmable dials [1], and future-proof for the next LED revolutions [2].
EG
