scout24
That's a Yuji mod beside a stock cool white Pak-lite. You do lose a bit of throw, but it's still good for 50 feet plus outdoors, and the low is oh-so-soft and floody. Carrot-PM incoming.
Oh--and moderators, feel free to pull this if I am out of line in posting it. No, I don't work for them or have any relationship with them, except I buy their products now and then and I used to live in Oregon....
Their website is advertising a 15% discount for the next few days. That brings the new Warm White down under $17.
I wish they would list lumen specs on the site and I hate it when a company leaves out that crucial info. Their super...ultra etc designations don't tell me useful info and I am seeing everywhere from 10-14 to 70-90 lumens on high depending on the review/search result.
I measured the Pak Lite to be about 36-40mA depending on sample and 1.2mA on low. More electrically oriented minds can probably form a reasonable guess from there.
Those are "tailcap" measurements, right? i.e. putting an ammeter in between the terminal of the battery and the terminal of the light? So the milliwatts into the circuit are nominal 9 times that?
I don't have the electronics chops to convert that into lumens, but it does roughly check out with the run-times that Pak-Lite claims, checked against the capacity of a Duracell coppertop. That has about 600mah, and they claim 600 hours on low, so they are saying it will average 1ma through the course of its life. If you read 1.2ma on a relatively full battery, then that would account for the discrepancy: it will start at 1.2ma, and drop throughout the 600 hours to average 1ma for the course.
[snip!]
Which checks out with another (anec)data point: I can tell when one of my batteries is basically dead, when the output on high is the same as the output on low.
I just need to find an adequate diffuser to make it an ideal lantern. In a short time I have gone from none to five of them.
Good idea! I wonder whether a latex or clear-ish vinyl glove would work well for this. Snip off a length of the thumb, for instance, and then slide it over the top with a bit of air trapped in the top to make it dome out. It could even make the light more waterproof if it was a tight fit.
I think this is more likely to work than trying to find a tube of lip-balm with a rectangular cap.
