Help> driving 3xCreeQ5 with 11.1V lion & Bflex
heatstroke
Please check my Maths :
I am stuck with a 11.1V 4400mAhr Lion battery.
I would like to drive 3xcreeQ5 in series with the Bflex at 750mA.
Each LED - vf = 3.42 (x3)
The fully charged Lion is 4.2v (x3)
Discharged Lion is about 2.65.
Am I correct in assuming I can use the Bflex till baattery voltage drops to 3.42 V before it goes into direct drive ? This should still give me about 80% of the battery capacity ?
At less than 1C discharge, how much voltage droop should I expect on the Lion batteries. (18650)
I am building a light for a friend and he does not have access to a 14.4 V lion charger, other wise I would rewire his 3s2p to a 4s1p pack.
Cheers
Rich
A Cree Q5 is probably 3.6-3.7 at 750 mA drive current(I've read reports of 4v at that current)
The driver, voltage sag, and other stuff, I don't know about.
Heatstroke;
I've built several Triple-Cree lights and the operating voltage is dependent on the final temperature of the LED's.
You should be close with 11.1 VDC and I would just use a resistor to set the current about 15% under where you want to end up.
This will allow for the slight LED voltage reduction after burn-in.
Most regulator circuits will drop ~ 1 volt which may be too much for your LED requirement.
Larry
