kramer5150
Sorry if this seems a bit redundant... I tried searching through all the 1000s of ROP threads and was not able to find the info I was looking for.
I found these 26700 cells and would like to use two of them in an ROP build
http://www.voltmanbatteries.com/servlet/the-3365/26650-BATTERY-REPLACES-A123/Detail
Can these cells handle the discharge rate of an ROP Hi and Lo?
Can the ROP PR bulbs handle the 8.4V total?
Can a MAG 6-cell PR bulb handle the 8.4V total?
What is the best mag host for this project?
Should I use a 3C host and DIY a spacer to bridge the extra space? or would I be better off with the larger sized 3D + DIY spacer tube, in an effort to try and keep the cells cool/isolated from the heat of the lamp?
thanks!!
thanks!!
