cryhavok
Hey Everyone,
My PD has been working perfectly for the past few weeks, but today it has started to malfunction. I left it on my desk and when I returned an hour later, it was on the low setting. Weird, I thought.
I went to unscrew it further to turn the low off and the low kept on until the O-ring was showing and it was barely screwed onto any threads.
The current function is that it will stay on low as soon as I start screwing the head on. The light goes off when I reach the final 1/2 turn before the head is screwed all the way down (which normally does low then high setting). If I back it off a bit, while the light is still in the abnormally off section, the PD works and I can get low/high by pressing. Backing off more, when the low starts on, pressing the piston actually turns off the low!
I've removed all the lube, thinking perhaps that the lube was making a conductive path somehow, but still get the same function. I've also changed batteries and get the same effect. Nothing looks out of the normal on the converter board, and the wire loop for the low setting is still slightly above the metal ring.
:help::help:
:help::help:
